Info for Old Fucked-Up Twats!
In case you didn't see this info in the other thread......I'll put it here again.
If you're so totally fucked up that you struggle to see things properly on here.....then you can change your view in the Customiser option.
880560593_Annotation2020-09-10140256.jpg.5a3163c6eb42186399f5eed128bdca8f.jpg.36c40a49391aa22fdaca1cc9159a4525.jpg
In there you can enlarge fonts in posts along with some other options that may suit you better.
The quality of the content here will still be shit but at least it'll be shit that's clearer to read!
14 minutes ago, Clive said:
Na.......don't need that............eye are fine with my reading specs...................it's my hearing that's fucked!.?
Same as me......all the years on bikes and nobody ever used earplugs.
I can't use them now......I keep getting ear infections with them.
Not much point using them anyway.......the damage is done.
7 hours ago, Mawsley said:
If you need to do that because you struggle to read posts then maybe you should be on an allotment instead of the internet
Had to get the bottle bottoms out for that one?
