Peon Maface Posted January 26, 2021 Share Posted January 26, 2021 UPDATE: KTM says the 1290 Super Adventure S will NOT be coming to North America for 2021. KTM officially announced the new 2021 1290 Super Adventure S, featuring a new frame, a low-slung fuel tank, Euro5 compliance and adaptive cruise control. The announcement confirms details we were first to report in December after the official pages for the 1290 Super Adventure were mistakenly published on KTM’s website. Not announced yet, but expected to come shortly, is the more off-road capable 1290 Super Adventure R which will receive similar updates. 2021 KTM 1290 Super Adventure R and S Details Leak The new chassis was designed to improve weight distribution for better handling. KTM moved the steering head back by 0.6 inches and the engine was rotated forward slightly, compared to the 2020 Super Adventure, changes KTM claims will result in sharper cornering. Meanwhile, the swingarm was lengthened for more stability under acceleration. The fuel tank has the same 6.1-gallon capacity as the 2020 model, but the low-slung saddle-shaped design helps to lower the 1290 Super Adventure S’ center of gravity. The tank has an electronically-opened cap and is integrated with a small storage compartment with a USB charging socket. A new subframe helps to lower the seat height of the 2021 model by half an inch to 33.4 inches, but if you need more room, it can be raised up to 34.2 inches. The handlebars are also adjustable, as is the new windshield which was optimized through wind tunnel testing. KTM redesigned the split headlight design to integrate the Bosch radar sensor. The adaptive cruise control system uses data from the radar to automatically adjust cruising speed to keep a safe distance from traffic. The adaptive cruise control joins a host of electronic rider aids returning for 2021. These include selectable ride modes, lean-sensitive traction control, off-road traction control, cornering and off-road ABS, stability control and self-cancelling turn signals as standard equipment. Motor slip regulation, hill hold control, and a quickshifter are available in an optional upgrade. To help control the electronics, the 2021 SA receives new illuminated handlebar switches and a seven-inch TFT display (formerly 6.5 inches on the 2020 model). The 1301cc V-Twin engine claims the same 160 hp output as the 2020 model while the claimed 101.8 lb-ft. of torque is down slightly from the previous model’s 103.2 lb-ft. The engine cases are thinner than on the previous engine, with KTM claiming a 3.5-pound weight reduction. A new dual-radiator and the revised bodywork combine to direct hot air away from the rider’s legs. The 2021 Super Adventure S receives the latest generation of WP’s Apex semi-active suspension with revised valves to augment damping using data from the 6D IMU. KTM also offers an upgraded suspension package with individual damping for the fork and shock, automatic preload adjustment and an anti-dive setting. The KTM 1290 Super Adventure S is not slated to come to North America, but we hope the R model will. Check back here on Motorcycle.com when the 1290 Super Adventure R is announced. 2021 KTM 1290 Super Adventure S Specifications Engine Type Liquid-cooled 4-stroke, 75° V-Twin, 4 valves per cylinder / DOHC Displacement 1301 cc Bore x Stroke 108 mm x 71 mm Power 160 hp @ 9,000 rpm (claimed) Torque 101.8 lb-ft. @ 6,500 rpm (claimed) Compression Ratio 13.1:1 Starter / Battery Electric starter / 12V 11.2Ah Transmission 6 gears Fuel System Keihin EFI (throttle body Ø 52 mm) Lubrication Pressure lubrication with 3 Eaton pumps Engine Oil Motorex, SAE 10W-50 Drive 525 X-ring chain Primary Drive 41:16:00 Final Drive 17:42 Clutch PASC slipper clutch, hydraulically operated Engine Management Keihin EMS with RBW and ACC (adaptive cruise control), double ignition Traction Control MTC (lean-angle sensitive, 4 modes, disengageable) Frame Chromium-Molybdenum-Steel trellis frame, powder coated Subframe Aluminum, powder coated Handlebar Aluminum, tapered, Ø 28 / 22 mm Front Suspension WP SAT (semi-active technology) Upside-Down Ø 48 mm, 7.9 inches of travel Rear Suspension WP SAT (semi-active technology) shock absorber, semi-active, electronically regulated preload, 7.9 inches of travel Front Brake 2 × Brembo 4-piston, radially mounted caliper, brake disc Ø 320 mm Rear Brake Brembo 2-piston, fixed caliper, brake disc Ø 267 mm Abs Bosch 10.3ME Combined-ABS (incl. Cornering-ABS and offroad mode, disenengageable) Front Wheel Cast aluminum 3.50 x 19″ Rear Wheel Cast aluminum 5.00 x 17″ Front Tire 120/70 ZR 19 Rear Tire 170/60 ZR 17 Silencer Stainless steel silencer Steering Head Angle 24.7°/4.3 inches Wheel Base 61.3 inches ± 0.6 inches Ground Clearance 8.8 inches Seat Height 33.4-34.2 inches (adjustable) Tank Capacity 6.1 gallons/1.3 gallons reserve Dry Weight approx. 485 pounds (claimed) Become a Motorcycle.com insider. Get the latest motorcycle news first by subscribing to our newsletter here. The post 2021 KTM 1290 Super Adventure S First Look appeared first on Motorcycle.com. http://feeds.feedburner.com/~r/Motorcyclefeed/~4/JqD6YkKeRUYSource Link to comment Share on other sites More sharing options...
