2023 Triumph Tiger 1200 Review – First Ride
Triumph’s open-class ADV bike, the Tiger 1200 (or Tiger Explorer depending on what era we’re talking about), had begun to get a little long in the tooth. The big cat hadn’t received a major overhaul since its introduction in 2012 – only receiving incremental upgrades to keep the machine relevant over the past 10 years. The Brits did give the bike some refreshes and new tech over that time, but nothing compared to the latest iteration that I was lucky enough to get a proper two-day test of around the backroads and trails of the Iberian Peninsula.
Less weight and more power. The all-new Tiger 1200 is following in its little brother’s footsteps.
Editor Score: 89.5%
Engine 18.5/20 Suspension 14/15 Transmission 9/10
Brakes 9.5/10 Instruments 3.5/5 Ergonomics 8.5/10
Appearance 9/10 Desirability 9/10 Value 8.5/10
  • Excellent adaptable suspension
  • Ride modes that make a difference
  • Weight loss
  • Engine mapping could use refinement
  • TFT lags
  • No more electronic windscreen… sigh
All-new! We hear all too often. Fortunately, however, when asked what components had been carried over from the previous Tiger 1200 family to these new models, Chief Engineer Stuart Wood replied with a smile, “I believe there are a few fasteners.” The 2023 Triumph Tiger 1200 is truly a ground up redesign. Before we dig into the bits and bobs, as they say, let’s take a look at what we have in the Tiger 1200 lineup.
All in the family
Five models make up the Tiger 1200 line for 2023. We have the GT subset which includes the standard GT, GT Pro, and GT Explorer. These models make up the more road-focused variants in a line which offers loads of touring comfort and tarmac performance, while still being game for the odd adventure. The Rally Pro and Rally Explorer models are better equipped for off-road expeditions with longer travel suspension and a 21-inch front wheel, among other things.
tiger 1200 lineup
Cast wheels in a 19/18-inch combo are standard fare on the GT models, allowing them to steer more quickly thanks to their smaller size and weight compared to the larger spoked wheels of the Rally models. Metzeler Tourance tires are standard issue.
triumph tiger 1200 gt pro
Showa semi-active suspension is used across the model range with the GT line offering up 7.9 inches of travel with 10% stiffer springs. Two-position seats are also equipped to all trim levels, with the GT’s ranging in height from 33.5 inches to 34.3 inches. The street-focused models are also a bit shorter in length and have a less steep rake and more trail than the off-road models.
Standout features of the Explorer models include a 7.9-gallon tank, engine protection bars, heated seats for the rider and passenger, and blind spot detection from its rear-facing radar.
triumph tiger 1200 rally
The Rally Pro and Explorer have slightly different skid plate designs, but both feature thicker bottom panels with slightly thinner pieces welded on at the sides for weight savings.
Rally models set themselves apart with 0.8-inches of extra suspension travel, giving them 8.7 in. of total travel at both ends. Additionally, the Offroad Pro ride mode is included, allowing users to disable traction control and ABS entirely. Metzeler Karoo Street tires are wrapped around tubeless spoked wheels in a proper 21/18-inch off-road combo. Seat heights range from 34.4 to 35.2 inches on the Rally models.
One of Triumph’s major engineering feats with the new 1200 range has been a substantial reduction in weight. The GT model comes in at a claimed 529 lbs with the largest model, the Rally Explorer tipping the scales at 575 elbees. Pricing for the GT models ranges from $19,100 to $23,100 while the Rally Pro and Rally Explorer retail for $22,500 and $24,200, respectively.
Tiger 1200 overview
As Mr. Wood alluded in his statement about fasteners, the 2023 Tiger 1200 range has been entirely revamped from the ground up. In this monumental task, Triumph’s goals were a reduction in weight, an increase in power, and improved rideability with more purposeful and focused performance for the task at hand.
2023 Triumph Tiger 1200 rally explorer
As is the trend with Triumph lately, the up/down quickshifter works most excellently.
Hinckley says the new package is more than 55 pounds lighter than before which, with our last top-o-the-line Tiger 1200 tipping the MO scales at 632 lbs, 575 for the ’23 Rally Explorer seems about right. Weight reduction comes from every nook and cranny of the Tiger 1200 with the frame, engine, and shaft drive being just a few areas showing considerable weight loss.
2023 Triumph Tiger 1200 engine
Despite cranking out more power, the new Tiger 1200 engine is actually 55 cc smaller at 1160 cc. The compression ratio however, has increased from 11.0:1 to 13.2:1.
The new, smaller 1160 cc Triple now uses the T-plane crank setup we first saw on the Tiger 900 range. The T-plane crank has a 1, 3, 2 firing order – a configuration Triumph uses to help coax Twin-like performance out of the Triple at low rpm while still delivering excellent power through the mid- to upper-rpm range that Hinckley’s Triples are known for. In addition, it makes for a pretty great soundtrack.
Triumph claims the new Triple makes 148 horsepower at 9,000 rpm and 96 lb-ft of torque at 7,000 rpm at the crank. The last Tiger 1200 we ran on the dyno during our 2018 Big Bore Adventure Touring Shootout made 114.6 hp at 8,600 rpm and 67 lb-ft of torque at 7,000 at the rear wheel.
2023 Triumph Tiger 1200 shaft drive
On previous models, you could really feel the weight of the single-sided shaft drive when riding off-road. With the new system, thanks to the lighter tri-link setup and the Showa electronic suspension, the ride feels much more controlled and balanced, closer to that of a standard chain final drive.
The Tiger 1200 retains shaft drive but now uses a single shaft versus the two-peice configuration from previous years. The new setup uses a “tri-link” setup forgoing the single-sided swingarm from previous years. Although it looks complex, we’re told tire changes only require one extra bolt to be removed compared to any other traditional double-sided swingarm. Triumph says the tri-link configuration saves more than three pounds of unsprung weight – not an insignificant amount. Recommended maintenance for the final drive is an oil refresh every two years regardless of mileage. That’s the kind of final drive maintenance schedule we can all get behind.
Speaking of maintenance, Triumph has also increased the new Triple’s service intervals to 10,000 miles for oil changes and 20,000 miles for valve checks.
2023 Triumph Tiger 1200 gt pro
The GT model’s footpegs are fairly low. While they’re great from a comfort standpoint, they tend to drag when the pace heats up.
We’re told the entire chassis, frame, and engine have been rotated forward in its design to place the bike’s center of gravity closer to the front contact patch, giving better front end feel to the rider.
The Showa semi-active suspension features many of the tricks we’ve come to expect from electronic suspension, including optimum damping settings for each ride mode; these are constantly adjusting at a rate of 50 milliseconds during the ride. There’s also the ability to adjust damping characteristics manually over nine levels, and automatic preload setting based on how the bike is loaded.
2023 Triumph Tiger 1200 rally pro
The suspension is also able to detect jumps and increase damping for landings. Showa also uses what it calls a “virtual spring rate” which, in theory, controls the spring rate by adjusting damping forces when the suspension is at higher stroke positions. This gives a progressive feel to the shock that is typically achieved through a linkage system.
Brembo Stylema
Excellent performance, as expected, out of the Brembo Stylemas.
Across the Tiger 1200 range, Brembo Stylema calipers clamp two 320mm discs at the front, with a single-piston Brembo unit clenching a 282mm disc out back. Continental’s IMU-based cornering ABS is also standard fare across the five trims. Braking is linked in all but off-road modes and uses specific ABS parameters that are based on ride modes.
On-road
I actually started my day of testing on the tarmac with the Rally Explorer. After half a day’s ride on that machine, the difference between it and the GT Pro that I hopped on after lunch was night and day. Really, it shouldn’t be surprising that the 21-inch front wheel and extra heft on the Explorer models was easily felt while railing through corners. Circling back to my comment about the new Tiger 1200 range feeling more focused, there is a massive difference in feel between the GT and Rally models, and it mainly boils down to the smaller, lighter cast wheels.
The extra heft and 21-inch front wheel of the Rally Explorer was noticeable on-road, but by no means a deal breaker.
Yes, you can feel the extra weight on the Explorer models and the larger front wheel on the Rallys, but it doesn’t take long to get used to and didn’t stop me from keeping up with the pack as we blasted through the Portuguese countryside.
The biggest feature that stood out after some time on the asphalt was just how well the suspension adapts to the road surface. Although I did tweak the damping characteristics in ride modes to get a feel for the differences, I never felt it was necessary. The baseline settings and semi-active suspension adjustment worked fantastically. Also, despite the amount of braking force generated by Brembo’s stellar Stylemas, the anti-dive damping works almost as well as the telelever setup found on other bikes (cough*BMW*cough). The Showa units are highly refined and complex and manage to work better than I thought was even possible. Big round of applause to Showa and Triumph. I am very impressed.
RIP to the electronically adjustable windscreen. The new one is easy to adjust with one hand though.
Naturally, the engine is the next standout feature. The 1160cc Triple lost some of its sewing machine smoothness in favor of a bit more bark and rawness. This did translate into a bit more vibes being carried through the machine, but not enough to bother me during our ride. That said, we were never droning down the highway for much time, but if we were, at least we have cruise control. In Sport mode, on/off throttle input can be a bit jerky, and really, it can be somewhat annoying when scooting through small towns at low speeds. However, slotting the Tiger into Road mode really seemed to smooth out the on/off throttle lurchiness.
2023 Triumph Tiger 1200 gt explorer
Triumph Tiger 1200 GT Explorer.
Once we had made our way out of town, I left the bike in Road mode for a bit which delivered a smooth, controlled ride from the suspension with an equally smooth delivery of power. Clicking the big cat back into Sport mode (via the aptly named joystick) for the twisty bits thoroughly changed the character of the bike. The stiffer suspension kept everything very well composed and the bike never felt like it was moving through the stroke too fast. Even in fast switchbacks, damping felt controlled and deliberate. Throttle response was much sharper with Sport mode, allowing the engine to rev up much quicker into its meaty mid-range as it smoothly climbed toward the bike’s 9,500 rpm redline.
2023 Triumph Tiger 1200 tft display
There is loads of adjustability available via the Tiger’s 7-inch TFT display though, on the preproduction units we were on, there was a noticeable lag while navigating the menus.
I really appreciated the difference between the ride modes. In the past, I’ve ridden motorcycles that, when switched between ride modes, don’t feel drastically different – with the Tiger 1200, you feel like you’ve just swapped motorcycles.
On the road, the GT Pro and its 5.2-gallon tank feel like the quickest of the bunch, as they should. Triumph has managed to make that bike feel small and manageable – compared to the other models – for an open-class ADV machine. With its smaller cast wheels, it’s easy to hustle through the tightest of corners with confidence that you can easily adjust mid-corner if necessary. That said, once I had some time on the GT Explorer, I found the front end even more planted and confidence inspiring. Yes, you can feel the weight of the extra fuel the Explorer carries (approximately 16.2 pounds worth) and it is all up high – there is no low slung tank like that of the KTM adventure bikes, but even still, it didn’t put a damper on our ride.
2023 Triumph Tiger 1200 explorer
Explorer models come equipped with a rear-facing radar for blind spot detection. The rider is alerted by a small light at the bottom of the rearview mirror. Some rider’s worried that this might be annoying, but after our ride, nobody seemed to think it was intrusive. The feature can also be shut off.
If I were looking for a road-biased British adventure bike, the Tiger 1200 GT Explorer would be the ticket. I like the extra fuel range, could take or leave the rear facing radar for blind spot detection – which does work quite well, whether with bikes or cars – and all the fantastic electronics that come with it.
Triumph’s ability to keep some of the character of the previous Tiger 1200, yet make it better in nearly every way, is a testament to the brand’s engineering prowess. Also, the fact that the machine feels so much different between modes – and with the amount of adjustment – really lets the rider decide how they like their dish served.
Thanks to the Tiger 1200’s new twin split-radiator setup and some clever air routing (the small duct just in front of my knee), I’m pleased to report the big Tiger no longer wafts an oppressive amount of heat onto the rider.
On the street, the Tiger 1200 is an absolute hoot to ride, thanks to its chassis composure and the engine’s excellent mid-range, which, when combined with strong brakes and ride modes that actually change the character of the machine, peg the limiter. The Tiger 1200 is causing some deja vu for me from our Middleweight Adventure comparison where the Tiger 900 Rally Pro showed up as an excellent all-around adventure machine, not focused too pointedly in any direction, but delivering well-rounded performance from every angle.
Off-road on the Rally Pro
Being able to handle business on the road isn’t enough though in the adventure-verse. It needs to be competent off-road as well. To be honest, I was worried after our street ride. I had switched between Road and Sport ride modes primarily and felt the motor, despite its new T-plane crank, was a bit soft on the bottom end. I assumed that during any slow going off-road I was going to be slipping the clutch quite a bit to keep the bike from stalling. We would see.
While the Tiger 1200 doesn’t hold a candle to the low-speed performance of the BMW GS, switching the bike into its Off-road modes again changes the character of the motorcycle more than I expected. The engine is still not as punchy at low-rpm as a big Twin, but there’s enough punch down there to have fun.
I’m a big fan of the Michelin Anakee Wilds. The Tiger 1200 Rally Pro offered excellent front end grip and feel off-road.
For our time off-road, Triumph had rotated the handlebar forward, removed the passenger footpegs from the bolt-on subframe, and equipped factory-spec Metzeler Karoo 3s. Otherwise, we were working with the stock settings.
2023 Triumph Tiger 1200 rally pro tft display
In Off-road mode, rear ABS is disabled and the front is dialed back to allow more slip before intervening. Off-road traction control is used to allow a safety net should your wrist be too heavy for your ambitions. Suspension can be adjusted separately in any ride mode, but again, at a medium pace, the stock default of 5/9 on the suspension scale seemed reasonable for those looking to have fun while traveling versus us speed-addicted journos hellbent on destruction.
The accessory footpegs equipped during our off-road day provided a larger platform for standing, but not as much grip as expected – particularly so when they were muddy.
After switching into Off-road Pro, ABS and traction control are a thing of the past, allowing for all the hooliganism you’re willing to get yourself into – and with 1160cc of Triple goodness between your legs, it’s hard to be mature. Damping settings are dialed up to 8/9 toward Sport, and as it was on the street, the Showa components do an excellent job of keeping the ride composed. I did manage to bottom the shock while riding at a hot pace, but even then, the bike didn’t spring back up wildly, the semi-active suspension keeps the action smooth in nearly every situation.
The biggest takeaway from the off-road ride, which consisted of mostly fire roads, but included single-track, two-track, a few loose climbs, and even some bits of sloppy mud was, again, the bike’s composure. The Tiger 1200 Rally Pro did a great job of staying in line whether I was breaking the rear end loose to slide around corners or hopping off little jumps on two-track trails. Feel from the front tire was excellent and immensely confidence inspiring on a bike of this size. To have some fun while still keeping it together for a full “adventure tour” – whatever that may mean to you – the Tigre 1200 should be an apt dance partner.
In the end
“Is the all-new Tiger 1200 better in every way,” I thought to myself? I think so. It’s lighter, more powerful, and handles much better overall than the outgoing models. Like the Tiger 900 Rally Pro which, in my opinion, is probably the best all-around middleweight adventure bike, the new 1200s seem to be following suit.
Maybe the Tiger 1200 is not the sportiest on-road, and perhaps it’s not the most hardcore off-road, but it does do both very well and it does so with all of the electronic adjustability and safety nets we’ve come to expect on these pricey adventure machines. Really though, there’s only one way to know for sure how the new Tiger compares to the stacked open-class adventure segment. I’d say it’s time to get the band back together.
alpinestars halo drystarHelmet: Shoei Hornet X2
Communicator: Cardo Packtalk Black
Jacket: Alpinestars Halo Drystar
Gloves: Alpinestars Chrome
Pants: Alpinestars Venture XT
Boots: Alpinestars Tech 7
2023 Triumph Tiger 1200 Specifications
GT GT Pro GT Explorer Rally Pro Rally Explorer
MSRP $19,100 $21,400 $23,100 $22,500 $24,200
Engine Type Liquid-cooled, 12 valve, DOHC, inline 3-cylinder
Displacement 1160 cc
Bore x Stroke 90.0 mm x 60.7 mm
Compression 13.2:1
Horsepower 148 hp at 9,000 rpm (claimed)
Torque 96 lb-ft. at 7,000 rpm (claimed)
Fuel System Multipoint sequential electronic fuel injection with electronic throttle control
Exhaust Stainless steel 3 into 1 header system with underslung primary silencer and side mounted secondary silencer
Final Drive Shaft drive
Clutch Hydraulic, wet, multi-plate, slip & assist
Transmission 6 speed
Frame Tubular steel frame, with forged aluminum outriggers. Fabricated, bolt-on aluminum rear subframe.
Swingarm Twin sided “Tri-Link” aluminum swingarm with twin aluminum torque arms.
Front Wheel Cast aluminum, 19 x 3.0in Spoked (tubeless), 21 x 2.15in.
Rear Wheel Cast aluminum, 18 x 4.25in Spoked (tubeless), 18 x 4.25in.
Front Tire Metzeler Tourance 120/70R19 (M/C 60V TL) Metzeler Karoo Street 90/90-21 (M/C 54V TL)
Rear Tire Metzeler Tourance 150/70R18 (M/C 70V TL) Metzeler Karoo Street 150/70R18 (M/C 70V TL)
Front Suspension Showa 49mm USD forks with semi-active damping; 7.9 inches of travel. Showa 49mm USD forks with semi-active damping; 8.7 inches of travel.
Rear Suspension Showa monoshock with semi-active damping and automatic electronic preload adjustment; 7.9 inches of travel. Showa monoshock with semi-active damping and automatic electronic preload adjustment; 8.7 inches of travel.
Front Brakes Brembo M4.30 Stylema monoblock radial calipers, OC-ABS, twin 320mm floating discs. Magura HC1 span adjustable radial master cylinder with separate reservoir.
Rear Brakes Brembo single piston caliper, OC-ABS, single 282mm disc. Rear master cylinder with remote reservoir.
Instruments Full-colour 7” TFT instrument pack with My Triumph Connectivity System
Length 88.4 inches 88.4 inches 88.8 inches 89.4 inches 90.4 inches
Width 33.4 inches (handlebars), 38.7 inches (handguards)
Height Without Mirrors 56.5 – 58.9 inches (adjustable screen) 58.5 – 60.9 inches (adjustable screen)
Seat Height 33.5 – 34.3 inches (adjustable) 34.4 – 35.2 inches (adjustable)
Wheelbase 61.4 inches
Rake 24.1° 23.7°
Trail 4.7 inches 4.4 inches
Wet Weight (Claimed) 529 pounds 540 pounds 562 pounds 549 pounds 575 pounds
Fuel Tank Capacity 5.3 gallons 5.3 gallons 7.9 gallons 5.3 gallons 7.9 gallons
03212022-Triumph-Tiger-1200-Review-_53I7 2023 Triumph Tiger 1200 rally pro 2023 Triumph Tiger 1200 rally pro 2023 Triumph Tiger 1200 2023 Triumph Tiger 1200 rally pro 2023 Triumph Tiger 1200 rally pro tft display 2023 Triumph Tiger 1200 rally pro 2023 Triumph Tiger 1200 2023 Triumph Tiger 1200 explorer 2023 Triumph Tiger 1200 shaft drive 2023 Triumph Tiger 1200 rally explorer 2023 Triumph Tiger 1200 gt pro Brembo Stylema 2023 Triumph Tiger 1200 rally pro 2023 Triumph Tiger 1200 rally explorer 2023 Triumph Tiger 1200 2023 Triumph Tiger 1200 gt explorer 2023 Triumph Tiger 1200 tft display 2023 Triumph Tiger 1200 engine 2023 Triumph Tiger 1200 rally explorer triumph tiger 1200 rally triumph tiger 1200 gt pro front wheel triumph tiger 1200 gt pro tiger 1200 lineup STU3966-150x150.jpg STU3768-150x150.jpg STU3754-150x150.jpg STU3783-150x150.jpg STU3813-150x150.jpg STU3811-150x150.jpg STU3742-150x150.jpg STU3757-150x150.jpg STU6039-150x150.jpg STU3790-150x150.jpg STU3784-150x150.jpg STU4028-150x150.jpg STU3750-150x150.jpg STU4029-150x150.jpg STU3745-150x150.jpg STU4016-150x150.jpg STU3802-150x150.jpg STU3817-150x150.jpg STU3656-150x150.jpg STU6048-150x150.jpg STU4071-150x150.jpg STU6061-150x150.jpg STU4104-150x150.jpg STU4064-150x150.jpg STU3680-150x150.jpg STU3866-150x150.jpg STU3872-150x150.jpg STU4099-150x150.jpg STU3735-150x150.jpg CW5D6605-150x150.jpg STU3708-150x150.jpg STU3720-150x150.jpg STU3668-1-150x150.jpg STU3898-150x150.jpg STU3683-150x150.jpg STU4088-150x150.jpg CW5D6599-150x150.jpg STU3730-150x150.jpg STU3860-150x150.jpg CW5D6601-150x150.jpg CW5D6615-150x150.jpg CW5D6575-150x150.jpg STU3727-150x150.jpg CW5D6603-150x150.jpg CW5D6617-150x150.jpg STU3733-150x150.jpg STU4061-150x150.jpg STU4075-150x150.jpg STU3901-150x150.jpg STU6058-150x150.jpg STU3691-150x150.jpg STU3875-150x150.jpg CW5D6574-150x150.jpg STU3844-150x150.jpg STU3677-150x150.jpg STU4124-150x150.jpg STU6041-150x150.jpg STU3887-150x150.jpg STU3717-1-150x150.jpg STU3851-150x150.jpg CW5D6626-150x150.jpg CW5D6593-150x150.jpg STU3847-150x150.jpg CW5D7855-150x150.jpg STU3853-150x150.jpg STU3674-150x150.jpg STU4084-150x150.jpg STU3714-150x150.jpg STU4052-150x150.jpg STU3927-150x150.jpg STU3885-150x150.jpg CW5D6590-150x150.jpg STU3661-150x150.jpg STU3856-150x150.jpg STU3739-150x150.jpg CW5D6621-1-150x150.jpg STU3704-150x150.jpg STU4043-150x150.jpg STU6046-150x150.jpg STU3658-150x150.jpg CW5D6581-150x150.jpg STU3869-150x150.jpg STU6050-150x150.jpg CW5D6597-150x150.jpg CW5D6583-150x150.jpg STU4069-150x150.jpg STU4055-150x150.jpg STU4097-150x150.jpg CW5D6622-150x150.jpg STU3897-150x150.jpg CW5D6623-150x150.jpg STU3698-150x150.jpg CW5D6637-150x150.jpg STU3833-150x150.jpg STU3827-150x150.jpg STU3748-150x150.jpg STU3788-150x150.jpg CW5D6645-150x150.jpg STU3777-150x150.jpg STU3762-150x150.jpg STU3951-150x150.jpg STU4021-150x150.jpg STU3773-150x150.jpg STU3820-150x150.jpg STU3759-150x150.jpg STU3823-150x150.jpg STU3943-150x150.jpg
The post 2023 Triumph Tiger 1200 Review – First Ride appeared first on Motorcycle.com.
