2022 Royal Enfield Classic 350 Review – First Ride
Things move at their own pace in the South. When it’s not stifling, the warm, humid breeze gently blowing through the Spanish moss-strewn southern live oaks relaxes in a way that you’d be hard-pressed to find elsewhere. It puts you in a southern state of mind – one where slowing down and living in the moment just feels like the thing to do. Royal Enfield’s new Classic 350 is the perfect pairing for such a place. A historic setting for a historic machine.
Historic Classic 350 styling with just enough modernity to make it easy to live with.
Editor Score: 81%
Engine 17.5/20 Suspension 12.5/15 Transmission 8/10
Brakes 6.5/10 Instruments 3/5 Ergonomics 7.5/10
Appearance 8.5/10 Desirability 8.5/10 Value 9/10
  • Smooth engine and transmission
  • Good looks with attention to detail
  • Approachable size
  • Questionable manufacturing decisions
  • Not quite fast enough for the speediest American freeways
  • I’m going to need more seat time
This new model is built from the same platform first introduced as the Meteor 350 a year ago, sharing much of the same componentry. We didn’t have a chance to test that bike, so the Classic would be MO’s first chance to throw a leg over Enfield’s modern air/oil-cooled 349cc Single. With the success of Royal Enfield’s recent models: the Himalayan and Twin-powered International and Continental GTs, I was curious to see if this new platform followed suit. From what I was told by Royal Enfield North America’s President, Krishnan Ramaswamy, we will have more to be excited about, too with a handful of new models to be released in the next 18 months or so (not all of which will be variants of existing platforms).
Everything you need, nothing you don’t
04152022-royal-enfield-classic-350-revie
The Dark series, available in Stealth Black (pictured) and Gunmetal Grey, come with cast wheels and tubeless CEAT tires. The other seven colorways including the Signals series (pictured in Marsh Grey) are equipped with spoked wheels that require tubes.
That’s how Ramaswamy described the Classic 350. What you see is what you get with the Classic. Sure, it has ABS, fuel injection, and electric start, but that pretty much covers the technology within. That’s not to say the 349cc Thumper isn’t an example of modern engineering though. Firing to life with the twist of a retro start/kill switch, the Single produces a satisfying thump from its single pea-shooter exhaust pipe.
The oversized accessory footpegs shown above made the already low shift lever much more difficult to get to. Being that they aren’t that much larger than the stock pegs, I can’t see any benefit in swapping to these.
You can feel the engine pulses at a standstill, but the moment you roll on the throttle the vibes are left behind giving way to a smooth ride thanks to its balancer shaft. It also delivers a bit more pep from a stop than I thought it would. Royal Enfield claims 20.2 hp at 6,100 rpm and 19.9 lb-ft of torque at 4,000 rpm. “It’s all about the torque,” says Ramaswamy. It’s true. For a bike destined to spend much of its time around town and on back roads tasked with mostly recreational riding, but expected to still pull daily duty, it makes sense to put an emphasis on the low end.
In addition to the oversized footpegs, my bike was equipped with the touring rider and passenger seats which are ribbed and finished with grey piping. I couldn’t tell much of a difference between the two seats during my limited time on the bike.
On an extended freeway cruise, the Classic 350 managed a top speed of 75 mph with me on board (with my chin bar on the tank). It was relatively easy to reach 65, but the miles per hour start to be more slowly achieved after that. Since you’ll be rowing through the five-speed gearbox quite a bit, I was thankful to find shifting to be smooth and positive, with pull at the clutch lever unlikely to cause fatigue for anyone.
Braking components are supplied by Bybre and get the job done, but at speed, you’ll want to plan on braking earlier than you might normally. Feel at the lever is mush, and the rear brake’s oversized pedal doesn’t allow for much finesse. It’s when you really try to dig into the braking power that you’re reminded that the Classic 350 does certainly have some heft to it.
The Classic 350 uses a 19/18 wheel combo.
The bike feels solid, I kept thinking to myself. Solid. It kept crossing my mind. Solid as in, well put together, giving a feeling of robustness, but at the same time, like a solid hunk of metal – which it is. RE claims 430 lbs with its 3.4-gallon tank 90% full of fuel. Unless you’re trying to stop in a hurry, the Classic carries its weight quite well with much of it low to the ground. The spec sheet says the seat height is 31.7 inches, but I would’ve guessed lower. It is also really well-balanced making low-speed u-turns and other maneuvers easy to carry out.
The Signals models (pictured in Desert Sand) are inspired by Royal Enfield’s association with Indian armed forces, and commemorate 65 years of working with the Indian army.
The suspension works a bit better than I expected as well. The non-adjustable fork uses 41mm tubes with 5.12 inches of travel and it’s a similar story in the rear, though there is a six-step adjustable preload from the twin rear shocks. Hard hits reveal the damping isn’t terribly complex, but normal conditions delivered a compliant ride without feeling too soft – as is often the case on lower-priced machines.
MY22-Classic350_HalyconForestGreenDS_000
RE tells us: “Later this season, look for the release of the Halcyon collection (pictured in Halcyon Forest Green), styled after the original 1950’s British roadsters. Halcyon Forest Green, Halcyon Black, and Halcyon Blue will be available for $4499. The Chrome Red and Chrome Brown models, featuring a mirror finish and special badging, will also be arriving later in 2022, and will be available for $4699.”
The bike looks somewhat small and is quick to turn around town, though, at highway speeds, the low CoG kept the bike stable. Ergonomically, at 5’8” with 30-inch getaway sticks, I found the Classic 350’s riding position perfectly neutral, though I might prefer the bars rotated back slightly. The bike being well-balanced combined with its low seat height inspired confidence while squirting around cobbled streets, weaving in and out of traffic. Unfortunately, I can’t comment on the machine’s cornering ability as there are no curves in or around Savannah, at least not that we rode.
First impressions are important
But they’re not everything. My first impressions were pretty positive. The Classic 350 is a subjectively good-looking motorcycle with fit, finish, and performance (as far as I could tell) that is worthy of a higher price point than its $4,500 starting MSRP would suggest. That said, I feel the need to explain that our first taste of the Classic 350 did not give us the chance to get much more than just that. The few Georgia natives that joined us on our test ride kept telling stories of how great the riding is up north. “If you’re out here in my neck of the woods (northern GA) give me a shout and I’ll show you some great riding.” Southern hospitality, as they say.
Unfortunately, as swell as Savannah is as a match for the Classic 350, the “lowlands” as I heard it called, of Georgia don’t make for the best proving grounds for motorcycle testing. Most of my time was spent bolt upright (as is evident in the photography) aside from the on-ramp to the bridge crossing into South Carolina where I managed to touch down the oversized accessory footpegs on the Dark model I was piloting. The roads were flat and straight. They kind of reminded me of riding in the middle of the US where I’m from – and also part of the reason I left.
As far as I can tell
The Classic 350 delivers on all of its promises. Everything you need, nothing that you don’t. The machine looked great in the Dark and Signal trims that we got to sample, with nice styling touches that elevate the machine’s presence. They feel tight and well-assembled (even if some components like the handlebar clamp seem puzzling), the transmission is smooth as southern bourbon and the 350 mill is as sweet as a Savannah praline.
The “Tiger Eyes” are just one example of the subtle interesting touches found throughout the Classic 350.
I’d like to spend more time with Royal Enfield’s Classic 350 – preferably one clad in Halcyon Forest Green or Chrome Brown when they’re available. It would be nice to live with the machine to see if it could truly be a great-looking all-rounder rather than just a Sunday cruiser. Time will tell, but the Classic 350 seems to be on par with Royal Enfield’s new era of excellent mid-sized machines.
04152022-royal-enfield-classic-350-revieHelmet: AGV X3000
Jacket: REV’IT! Prometheus
Gloves: Racer Mickey
Jeans: SA1NT Unbreakable
Boots: Red Wing Iron Ranger
2022 Royal Enfield Classic 350 Specifications
Engine Type Single-cylinder, air/oil-cooled four-stroke
Displacement 349cc
Bore x Stroke 72.0 x 85.8 mm
Compression Ratio 9.5 : 1
Horsepower 20.2 bhp @ 6100 rpm (claimed)
Torque 19.9 lb-ft @ 4000 rpm (claimed)
Clutch Wet, multi-plate
Gearbox 5 Speed, constant mesh
Lubrication Wet sump, forced lubrication
Engine Oil SAE 15W-50 API, SL Grade, JASO MA 2 semi-synthetic
Fuel Supply Electronic Fuel Injection
Air Cleaner Paper element
Starter Electric
Frame Twin downtube spine frame
Front Suspension Telescopic, 41mm Forks, 5.1 inches of travel
Rear Suspension Twin tube emulsion shock absorbers w/ 6-step adjustable preload
Front Brake 300 mm Disc, Bybre twin piston floating caliper
Rear Brake 270 mm Disc, Bybre single piston floating caliper
ABS Dual Channel
Front Tire 100/90 – 19″ – 57P
Rear Tire 120/80 – 18″ – 62P
Wheelbase 54.7 inches
Ground Clearance 6.7 inches
Length 84.45 inches
Width 30.9 inches (without mirrors)
Height 42.91 inches (without mirrors)
Seat Height 31.69 inches
Curb Weight 430 lbs (with 90% fuel & oil), claimed
Fuel Capacity 3.43 gallons
Electrical System 12V – DC
Battery 12V, 8 AH, VRLA (Maintenance free)
Head Lamp 12V, H4-60/55W (Halogen) w/ LED Light Guide
Tail Lamp 12V, P21/5W
Turn Signal Lamp 12V, 10W x 2 Nos.
04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 2022 Royal Enfield Classic 350 Review 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie 04152022-royal-enfield-classic-350-revie MY22-Classic350_ChromeBrownDS_003-150x15 MY22-Classic350_ChromeRedDS_001-150x150. MY22-Classic350_DarkStealthDS_002_wo_tri MY22-Classic350_GunMetalGreyDS_001-150x1 MY22-Classic350_HalyconBlackDS_001-150x1 MY22-Classic350_HalyconBlueDS_003-150x15 MY22-Classic350_HalyconForestGreenDS_000 MY22-Classic350_RedditchGreyDS_005-150x1 MY22-Classic350_SignalsDessertDS_000-150 MY22-Classic350_SignalsMarshDS_003-150x1
The post 2022 Royal Enfield Classic 350 Review – First Ride appeared first on Motorcycle.com.
