2023 Honda Rebel 1100T First Look
As we reported last month, Honda is introducing a new bagger version of the Rebel 1100. The 2023 Honda Rebel 1100T adds a fork-mounted fairing and color-matched hard panniers. For the U.S., the bagger model will only be offered with DCT, while some markets may offer a manual transmission option.
110722-2023-Honda-Rebel-1100T-DCT_Metall
The fairing offers more protection from the elements, while the lockable saddlebags offer 35 liters of storage, giving the big Rebel some added touring versatility. Unfortunately, the fuel tank has the same 3.6-gallon capacity as the regular Rebel 1100, so don’t expect much difference in range.
The fairing and luggage increases the curb weight by 33 to a claimed 542 pounds for the Rebel 1100T DCT, compared to 509 pounds for the regular DCT model and 487 pounds for the manual transmission Rebel 1100.
Apart from the bagger accoutrements, the Rebel 1100T DCT is mechanically similar to the Rebel 1100 DCT, with the same 1083 cc Parallel-Twin derived from the Africa Twin.
2023 Honda Rebel 1100T DCT Metallic Black
The suspension is comprised of a telescopic fork offering 5.5 inches of travel and dual Showa rear shocks with adjustable preload and 3.7 inches of travel.  A single four-piston monoblock, radial-mount hydraulic caliper and floating 330mm rotor are paired to the 18-inch front wheel. The 16-inch rear wheel is matched with a single one-piston hydraulic caliper and 256mm rotor. ABS comes standard, as do traction control, wheelie control, engine braking control, three selectable ride modes, and cruise control.
For the U.S., 2023 Honda Rebel 1100T will be offered in a choice of Metallic Black and Bordeaux Red Metallic for $11,299, compared to $9,499 for the Rebel 1100 and $10,099 for the Rebel 1100 DCT.
2023 Honda Rebel 1100 Specifications
Rebel 1100 (CMX1100) Rebel 1100 DCT (CMX1100D) Rebel 1100T DCT (CMX1100TD)
Engine Type 1,083cc liquid-cooled Unicam four-stroke 22.5º parallel-twin
Valve Train SOHC; four valves per cylinder
Bore x Stroke 92.0mm x 81.5mm
Compression Ratio 10.1:1
Induction PGM-FI electronic fuel injection w/ 46mm throttle bodies (Throttle By Wire)
Ignition Full transistorized ignition
Starter Electric
Transmission 6 speed manual 6 speed automatic DCT
Clutch Multiplate wet (2) multiplate wet
Final Drive 525 chain, 16T x 42T
Front Suspension 43mm conventional telescopic fork w/ adj. preload & dark titanium oxide coating; 5.5 in. travel
Rear Suspension Dual Showa shocks w/ 12.5mm shafts & adj. preload, piggyback pressurized reservoirs; 3.7 in. travel
Front Brakes Single four-piston monobloc, radial-mount hydraulic caliper w/ floating 330mm rotor; ABS
Rear Brakes Single one-piston hydraulic caliper w/ 256mm rotor; ABS
Front Tires 130/70-18
Rear Tires 180/65-16
Rake 28º
Trail 110mm (4.3 in.)
Length 88.3 in.
Width 33.6 in. 32.8 in. 33.4 in.
Height 43.9 in. 46.5 in.
Seat Height 27.5 in.
Ground Clearance 4.7 in.
Wheelbase 59.8 in.
Fuel Capacity 3.6 gal. (1.1 gal. Reserve)
Curb Weight 487 lbs. (claimed) 509 lbs. (claimed) 542 lbs. (claimed)
Colors Iridium Gray Metallic; Green Metallic Metallic Black; Bordeaux Red Metallic
110722-2023-Honda-Rebel-1100T-DCT_Bordea 110722-2023-Honda-Rebel-1100T-DCT_Bordea 110722-2023-Honda-Rebel-1100T-DCT_Metall 110722-2023-Honda-Rebel-1100T-DCT_Metall 110722-2023-Honda-Rebel-1100T-DCT_Metall 110722-2023-Honda-Rebel-1100T-DCT_Metall 110722-2023-Honda-Rebel-1100T-DCT_Metall 110722-2023-Honda-Rebel-1100T-DCT_Metall 110722-2023-Honda-Rebel-1100T-DCT_Metall
The post 2023 Honda Rebel 1100T First Look appeared first on Motorcycle.com.
