Marcel le Moose Fondler Posted November 9, 2022 Share Posted November 9, 2022 To the shiters.... Had to replace a defective pcv valve from a 2013 Chevy trax... Pcv valve is built in the valve cover.. So the valve cover has to be replaced... Its not serviceable... Ordered the part directly from the chevy dealer and look what was on it.. What the hell? 5 Link to comment Share on other sites More sharing options...
Catteeclan Posted November 10, 2022 Share Posted November 10, 2022 7 hours ago, Marcel said: To the shiters.... Had to replace a defective pcv valve from a 2013 Chevy trax... Pcv valve is built in the valve cover.. So the valve cover has to be replaced... Its not serviceable... Ordered the part directly from the chevy dealer and look what was on it.. What the hell? I rather that than the Chinese crap everyone else seems to be using. Link to comment Share on other sites More sharing options...
XTreme Posted November 10, 2022 Share Posted November 10, 2022 8 hours ago, Marcel said: To the shiters.... Had to replace a defective pcv valve from a 2013 Chevy trax... Pcv valve is built in the valve cover.. So the valve cover has to be replaced... Its not serviceable... Ordered the part directly from the chevy dealer and look what was on it.. What the hell? 2 Link to comment Share on other sites More sharing options...
boboneleg Posted November 10, 2022 Share Posted November 10, 2022 I bet it was a fat munter who made it ..................... 6 Link to comment Share on other sites More sharing options...
Sir Fallsalot Posted November 10, 2022 Share Posted November 10, 2022 1 minute ago, boboneleg said: I bet it was a fat munter who made it ..................... Probably not Bob i have it on good authority that they do fuck all 4 Link to comment Share on other sites More sharing options...
Marcel le Moose Fondler Posted November 10, 2022 Author Share Posted November 10, 2022 2 hours ago, Catteeclan said: I rather that than the Chinese crap everyone else seems to be using. Yes I agree...the aftermarket parts suppliers are flooded with everything made in China and it's been going on for years... Its was actually a good qwality part and cheap... 109 Ca retail. 3 Link to comment Share on other sites More sharing options...
Marcel le Moose Fondler Posted November 10, 2022 Author Share Posted November 10, 2022 24 minutes ago, Sir Fallsalot said: Probably not Bob i have it on good authority that they do fuck all Do you think it's because of lazyness.. Or just because they work the system to their advantage.. 1 Link to comment Share on other sites More sharing options...
Marcel le Moose Fondler Posted November 10, 2022 Author Share Posted November 10, 2022 It took a little while to zero in on the problem.. It was throwing on false codes.. Fuel air mixture.. Mass air flow...it's a 1.5 l with a turbo.. Though maybe I had a falling turbo for a few... But after pulling the running data...their was to much air entering at idle..... It use to be so simple before.. Just remove the pcv valve and plug the hole with your finger... Not the case anymore... 1 Link to comment Share on other sites More sharing options...
XTreme Posted November 10, 2022 Share Posted November 10, 2022 30 minutes ago, Marcel said: It took a little while to zero in on the problem.. It was throwing on false codes.. Fuel air mixture.. Mass air flow...it's a 1.5 l with a turbo.. Though maybe I had a falling turbo for a few... But after pulling the running data...their was to much air entering at idle..... It use to be so simple before.. Just remove the pcv valve and plug the hole with your finger... Not the case anymore... 1 Link to comment Share on other sites More sharing options...
Marcel le Moose Fondler Posted November 10, 2022 Author Share Posted November 10, 2022 2 minutes ago, XTreme said: What.. did you think I was a successful auto repair guy just cause of my good looks... 4 Link to comment Share on other sites More sharing options...
