Hugh Janus Posted February 10, 2023 Share Posted February 10, 2023 2023 Suzuki V-Strom 800DE. (Suzuki/)UpsName aside, there’s nothing shared with the ancient V-Strom 650New parallel-twin engine makes for a compact, competitive packageHigh-spec suspension, brakes, and electronicsDR Big-inspired styling is distinctive, if not universally lovedDownsLess power than Honda’s new Transalp or BMW’s F 850 GSHeavier than a Transalp or Ténéré 700Still not as performance-minded as some of the competitorsVerdictFor twenty years Suzuki has been churning out soft adventure bikes bearing the V-Strom name, but the V-Strom 800DE looks to push Suzuki down a new path. On paper it’s the most convincing bike yet to wear the V-Strom badge.V-Strom 800DE Adventure models come standard with quick-release 37L aluminum panniers, and some adventure-focused hardware. (Suzuki/)OverviewSitting between the V-Strom 1050DE and the V-Strom 650XT in Suzuki’s adventure range, the 800DE ditches the V-twin format and alloy chassis in favor of a steel frame and an on-trend parallel-twin. Using the first all-new engine we’ve seen from Suzuki in years— and one that aims to be as ubiquitous as the V-twins used in the other V-Strom models—it’s hard to overstate how important the 800DE is to Suzuki’s future.Suzuki proudly claims that the 800DE is “the most dirt- and travel-worthy V-Strom ever.” There’s more ground clearance than any V-Strom to date thanks to long-travel, fully adjustable suspension, and there’s plenty of technology baked into the package. For those with travel plans, 800DE models come standard with aluminum panniers.The 800DE’s design is a welcomed departure from the outdated design used for Suzuki’s 650 platform. (Suzuki/)Updates for 2023Everything about the V-Strom 800DE is new, from the fully adjustable Showa suspension to the wire wheels (tubed, hinting at the bike’s off-road intention) and, of course, the engine and frame. Styling has a nod to the DR Big but isn’t retro, borrowing modern Suzuki cues like the stacked, rectangular lights that debuted on the latest GSX-S1000.Pricing And VariantsThe key decision to make is between the base V-Strom 800DE ($11,349) and the better-equipped 800DE Adventure ($12,999). Base model comes in yellow/blue and gray/yellow color schemes, while the Adventure is available in black with blue trim.More importantly, upgrading to the 800DE Adventure gets you quick-release 37-liter aluminum panniers, an aluminum skid plate, and an “accessory bar,” which Suzuki won’t refer to as an engine guard.With the 800DE, Suzuki looks to offer a more adventure-worthy option to the growing legion of adventure bike riders. (Suzuki/)CompetitionThe parallel-twin layout, semi-serious off-road stance, and ability of the V-Strom 800DE mean it’s up against a host of tough rivals. BMW’s F 850 GS ($12,595), Yamaha’s Ténéré 700 ($10,499), KTM’s 890 Adventure ($13,949), and Aprilia’s Tuareg 660 ($12,299) are all potential competitors, each sharing a similar steel-framed, parallel-twin-powered design, and even Honda’s larger Africa Twin ($14,499) could be cross-shopped against the Suzuki.Powertrain: Engine, Transmission, and PerformanceThe engine is the key to the V-Strom 800DE’s appeal. The parallel-twin layout isn’t just a case of following trends—it makes sense in terms of having a lower component count than a V-twin, it’s easier to package in a bike’s frame, and it’s inevitably lighter. A 270-degree crankshaft means the power delivery still promises a characterful throb like that of a 90-degree V-twin, and Suzuki uses a patented dual-balancer-shaft arrangement that promises to make it smoother than most engines using this layout.Tuned for midrange thrust rather than outright power, the Suzuki peaks at a claimed 83 hp and 8,500 rpm, which is around 11 hp more than the claim power output for Yamaha’s Ténéré 700, but less than the 90 hp BMW F 850 GS, or 105 hp KTM 890 Adventure. It drives through a six-speed transmission equipped with an up-and-down quickshifter that’s part of the 800DE’s surprisingly generous standard equipment.Showa suspension is fully adjustable at front and rear. (Suzuki/)Chassis/HandlingSome might see Suzuki’s use of a steel frame as a retrograde step, given the use of aluminum on earlier V-Stroms, but again it’s in line with current trends. Steel copes well with the tough conditions that adventure bikes are aimed at, flexing when necessary but without fracturing; all the 800DE’s main rivals use a similar solution. The bolt-on, trellis-style subframe is also steel, but the swingarm is an alloy design. Unlike Honda’s Transalp 750, which borrows its frame from the Hornet street bike, the 800DE’s chassis is quite different from the one used in the GSX-8S roadster that shares this engine.The Suzuki also has higher-spec suspension than some rivals, with an inverted fork and a shock from Showa, both fully-adjustable for compression, rebound, and spring preload. Wheel travel is 8.7 in. at the front and rear.Suzuki refers to the V-Strom 800DE as “the most dirt- and travel-worthy V-Strom ever.” (Suzuki/)BrakesNissin provides the braking setup, with simple, axial-mounted 2-piston front calipers and a single-pot rear, using dual 310mm front discs and a 240mm one at the back. There’s two ABS modes, selectable along with the other rider aids, plus an option to turn off the rear antilock entirely when riding off-road.Fuel Economy and Real-World MPGThe fuel tank is a large, 5.3 gallon design, and according to specs released for the European model (done using World Motorcycle Test Cycle conditions), fuel consumption is 53.4 mpg. That will equate to a range of around 280 miles if you can achieve the same efficiency in the real world.Ergonomics: Comfort and UtilityThe V-Strom 800DE’s more serious approach to off-road hasn’t led to a crazily high seat, which comes in at 33.7 inches—around the same as the Transalp and nearly an inch lower than a KTM 890 Adventure R or a Yamaha Ténéré 700. The tougher skid plate and side protection bars of the 800DE Adventure look like worthwhile additions for anyone venturing far from the beaten track, but even the base model has a plastic engine guard and hand protectors as standard. The quick-release black anodized alloy panniers of the Adventure have 37 liters (1.3 cu.-ft.) of space.A 5-inch TFT display is a welcome addition to the V-Strom lineup. (Suzuki/)ElectronicsThe V-Strom 800DE’s rider aids are in line with current expectations, but that means they’ll be a big leap forward for anyone swapping from a bike even just five years old. Three riding modes—A, B, or C—change the torque delivery from sharp to gentle, and four traction control settings match them, with an additional Gravel setting for dirt roads. Two ABS modes change the level of interference and the rear wheel ABS can be switched off, and it’s all accessed via a 5-inch TFT color dash that includes a programmable gearshift indicator and a built-in USB port. The quickshifter is standard and includes a blipper to automatically rev-match downshifts. Suzuki’s Low RPM assist helps prevent stalls, and all the lighting is LED.Warranty and Maintenance CoverageThere’s a 12-month, unlimited mileage, limited warranty with the option to extend to longer cover periods via Suzuki Extended Protection.2023 Suzuki V-Strom 800DE Claimed Specs MSRP: $11,349 / $12,999 (Adventure) Engine: DOHC, 776cc, liquid-cooled parallel twin, 4 valves/cyl. Bore x Stroke: 84.0mm x 70.0mm Transmission/Final Drive: 6-speed/chain Fuel Delivery: Electronic fuel injection w/42mm throttle bodies Clutch: Wet, multiple disc Engine Management/Ignition: Ride by wire with multiple modes Frame: Steel tube frame with bolt-on trellis subframe Front Suspension: Showa USD fork, fully adjustable, 8.7 in. travel Rear Suspension: Showa shock, fully adjustable; 8.7 in. travel Front Brake: 2-piston calipers, dual 310mm discs w/ ABS (2 modes) Rear Brake: 1-piston caliper, 240mm disc w/ ABS (2 modes or disengaged) Wheels, Front/Rear: Wire-spoked wheels w/ aluminum rims, 21 in. front / 17 in. rear Tires, Front/Rear: 90/90-21 / 150/70-17 Rake/Trail: 28.0°/4.5 in. Wheelbase: 61.8 in. Ground Clearance: 8.7 in. Seat Height: 33.7 in. Fuel Capacity: 5.3 gal. Wet Weight: 507 lb. Contact: suzukicycles.com Source Link to comment Share on other sites More sharing options...
XTreme Posted February 10, 2023 Share Posted February 10, 2023 230kg? That's a bit hefty! Link to comment Share on other sites More sharing options...
Pedro Posted February 10, 2023 Share Posted February 10, 2023 Cool bike, shame about the lack of VTwin though. Link to comment Share on other sites More sharing options...
boboneleg Posted February 10, 2023 Share Posted February 10, 2023 Suzuki have lost the plot in recent years , a nice yellow ain't going to sell a bike whenb the competitor has more power and is lighter . 1 Link to comment Share on other sites More sharing options...
Buckster Posted February 12, 2023 Share Posted February 12, 2023 How is it a “v” Strom if it has a parallel twin? With the amount of rake on the forks that will be a nightmare off-road when it gets out of shape. Link to comment Share on other sites More sharing options...
Pedro Posted February 12, 2023 Share Posted February 12, 2023 5 hours ago, Buckster said: How is it a “v” Strom if it has a parallel twin? With the amount of rake on the forks that will be a nightmare off-road when it gets out of shape. They could have gotten in trouble with Apple if they named it an I-Strom 1 Link to comment Share on other sites More sharing options...
Buckster Posted February 12, 2023 Share Posted February 12, 2023 18 minutes ago, Pedro said: They could have gotten in trouble with Apple if they named it an I-Strom Looks more of a lemon than an apple. 2 Link to comment Share on other sites More sharing options...
