Datboi Posted April 9, 2024 Share Posted April 9, 2024 have a bmw k100 rs that hasn't run since 2019, i filled the tank up with gas and stabilizer to prevent rust in the tank. other than that i didn't do much. i read that you should put fresh oil when storing for a long time because oil turns acidic and can damage the engine. I'm very skeptical of this claim and i think there is no evidence supporting it, am i wrong? lets start with the shaft drive oil, my Toyota went from 2008, 200k, until a few months ago without a differential and transfer case oil change. no issues that's 16 years of running the car almost daily. now, about the engine oil, how exactly would it hurt even if it turned acidic? what components could it damage just sitting there not running? does anyone have evidence supporting these claims or is this just bro science? to be honest i really can't be bothered to change the oil and spend some money on new oil that will have to be drained away anyways when the bike will come out of storage. guessing there are no issues with the coolant turning corrosive and such? anything else to do for this long term storage? 2 Link to comment Share on other sites More sharing options...
XTreme Posted April 9, 2024 Share Posted April 9, 2024 3 minutes ago, Datboi said: have a bmw k100 rs that hasn't run since 2019, i filled the tank up with gas and stabilizer to prevent rust in the tank. other than that i didn't do much. i read that you should put fresh oil when storing for a long time because oil turns acidic and can damage the engine. I'm very skeptical of this claim and i think there is no evidence supporting it, am i wrong? lets start with the shaft drive oil, my Toyota went from 2008, 200k, until a few months ago without a differential and transfer case oil change. no issues that's 16 years of running the car almost daily. now, about the engine oil, how exactly would it hurt even if it turned acidic? what components could it damage just sitting there not running? does anyone have evidence supporting these claims or is this just bro science? to be honest i really can't be bothered to change the oil and spend some money on new oil that will have to be drained away anyways when the bike will come out of storage. guessing there are no issues with the coolant turning corrosive and such? anything else to do for this long term storage? I'd definitely change the oil.......but others can advise on coolant. Link to comment Share on other sites More sharing options...
boboneleg Posted April 9, 2024 Share Posted April 9, 2024 I don't know much about that bike but the worse thing now with storing bikes for a long time is the fuel. I see that you've used a stabilizer but that doesn't always stop the injectors getting gummed up. Link to comment Share on other sites More sharing options...
Datboi Posted April 9, 2024 Author Share Posted April 9, 2024 Just now, boboneleg said: I don't know much about that bike but the worse thing now with storing bikes for a long time is the fuel. I see that you've used a stabilizer but that doesn't always stop the injectors getting gummed up. yeah i plan on draining it all out when time comes to use the bike, about injectors, I was told it's not an issues - unlike carbs they don't store much if any fuel inside the injector itself, is this information wrong? 1 Link to comment Share on other sites More sharing options...
boboneleg Posted April 9, 2024 Share Posted April 9, 2024 Just now, Datboi said: yeah i plan on draining it all out when time comes to use the bike, about injectors, I was told it's not an issues - unlike carbs they don't store much if any fuel inside the injector itself, is this information wrong? It might be warmer (less humid) where you are but we get problems with blocked injectors and expanding fuel hoses with the crap fuel and humidity here Link to comment Share on other sites More sharing options...
Datboi Posted April 9, 2024 Author Share Posted April 9, 2024 3 minutes ago, boboneleg said: It might be warmer (less humid) where you are but we get problems with blocked injectors and expanding fuel hoses with the crap fuel and humidity here what would be the solution? i ran the bike dry initially, but the issue is that the tank can rust, that's why I filled it back up. we can only get e5 or e10 garbage fuel here unfortunately Link to comment Share on other sites More sharing options...
busabeast Posted April 9, 2024 Share Posted April 9, 2024 42 minutes ago, XTreme said: I'd definitely change the oil.......but others can advise on coolant. fixed for you pete 1 Link to comment Share on other sites More sharing options...
Pedro Posted April 9, 2024 Share Posted April 9, 2024 If it’s been untouched since 2019, all that could go wrong has already happened. Worry about it when you get it going, or you’ll just end up doing the same thing twice. Doing stuff to it now, without a few proper runs to eliminate humidity before storing it again will hurt more than do good. Oil does get acidic from contact with combustion and fuel residues, humidity and time, hence it’s usually advised to change the oil yearly if you care about the engine and it gets little use. If the 10 or 15 Euros it costs to buy some cheap oil to put in it while not running is too much of an expense just let it be and do it when getting it to go again. 2 Link to comment Share on other sites More sharing options...
boboneleg Posted April 9, 2024 Share Posted April 9, 2024 I would just try and start it first , keep your eye on the temperature gauge once it's been running for a couple minutes , turn it off and check the oil to make sure it's not milky . If that's all good take it for a short run (keep close to home) to check that the brakes are still good. 2 Link to comment Share on other sites More sharing options...
Pedro Posted April 9, 2024 Share Posted April 9, 2024 2 hours ago, Datboi said: lets start with the shaft drive oil, my Toyota went from 2008, 200k, until a few months ago without a differential and transfer case oil change. no issues that's 16 years of running the car almost daily. I would keep to the BMW service intervals, as a maximum, oil is cheaper than metal. Change it when you get it back on the road. Or check your Toyota’s service manual to see what should be done on your motorcycle, if that makes sense. It doesn’t to me. 1 Link to comment Share on other sites More sharing options...
Catteeclan Posted April 10, 2024 Share Posted April 10, 2024 Get it started and dump all the fluids when warm. Coolant has a life span and should be replaced. Link to comment Share on other sites More sharing options...
Six30 Posted April 11, 2024 Share Posted April 11, 2024 On 09/04/2024 at 19:29, Datboi said: have a bmw k100 rs that hasn't run since 2019, i filled the tank up with gas and stabilizer to prevent rust in the tank. other than that i didn't do much. i read that you should put fresh oil when storing for a long time because oil turns acidic and can damage the engine. I'm very skeptical of this claim and i think there is no evidence supporting it, am i wrong? lets start with the shaft drive oil, my Toyota went from 2008, 200k, until a few months ago without a differential and transfer case oil change. no issues that's 16 years of running the car almost daily. now, about the engine oil, how exactly would it hurt even if it turned acidic? what components could it damage just sitting there not running? does anyone have evidence supporting these claims or is this just bro science? to be honest i really can't be bothered to change the oil and spend some money on new oil that will have to be drained away anyways when the bike will come out of storage. guessing there are no issues with the coolant turning corrosive and such? anything else to do for this long term storage? Hello Link to comment Share on other sites More sharing options...
Buckster Posted April 20, 2024 Share Posted April 20, 2024 When are you expecting to be sentenced? 1 Link to comment Share on other sites More sharing options...
Buckster Posted April 20, 2024 Share Posted April 20, 2024 11 minutes ago, Marcel le Moose Fondler said: Think we lost him....Beemer Bumm fuck was trying to get fresh with him... He will get plenty of that inside. Link to comment Share on other sites More sharing options...
boboneleg Posted April 20, 2024 Share Posted April 20, 2024 Is dat it @Datboi Link to comment Share on other sites More sharing options...
Six30 Posted April 20, 2024 Share Posted April 20, 2024 bet the tank in his avy is in reverse Link to comment Share on other sites More sharing options...
Datboi Posted July 9, 2024 Author Share Posted July 9, 2024 update: after 5 years of storage, i connected a battery, put some gas in it, and she fired up like she last ran yesterday. i ran it for 15 mins, and did an oil change with fresh oil, then I ran the bike for another 5 mins to get the engine coated in the new oil, and waited for it to die from lack of gas. also added a bit of fuel stabilizer just incase some fuel remains in the injectors even after running it empty. i checked the coolant overflow, there was 5 metric tons of limescale in it, as I always say, better to do the work yourself! my father brought this bike since 87' to BMW for servicing, and they put water from the tap instead of distilled water, unbelievable. i cleaned the overflow with vinegar to get all the limescale off. eventually, when I'll bring this bike back to life I'll do some deep cleaning because the coolant tunnels are probably full of gunk and limescale. as for changing coolant, gear oil, and brake oil - too much work ain't got the time, especially for a bike I'm not gonna use, as other have stated it's already been like this for 5 years so potentially if something had to go wrong it probably already did. main reason I changed the oil is that I was told it turns acidic from carbon deposits and combustion and it can damage some o-rings and such, so I put some fresh cheap semi-synthetic oil in it. 3 Link to comment Share on other sites More sharing options...
Pedro Posted July 9, 2024 Share Posted July 9, 2024 Good stuff. I’m sure you will be fine when time comes to get it running. Link to comment Share on other sites More sharing options...
Buckster Posted July 9, 2024 Share Posted July 9, 2024 It is a icon now that bmw have modelled the new gs bodywork on the K engine. 3 Link to comment Share on other sites More sharing options...
